Siberian Larch offcuts. Keep or not?
Glitch
23 Oct 2020
London
I've got 30-40 offcuts of Siberian Larch cladding from my shed build. Roughly 320 x145mm
Having a tidy up and need to decide whether to chuck them or not.
Thought I could make bird boxes and offer them to neighbours.
Any other suggestions?
TRITON
5 Oct 2014
Sunny Glasgow
Long enough and wide enough to justify keeping. But I'd look to make something reasonably quickly before they start cupping too much
MARK.B.
4 Jul 2012
East Yorkshire
Bird/Bat boxes(y). Or Laminate them together with contrasting wood layers for turning or band saw boxes etc, mind you the temp in my shop is dropping fast so kindling for the wood burner would be my choice ;);)
TKB
New member
17 Feb 2021
North Yorks
I’ve also quite a stack of larch offcuts from a workshop build and had wondered about using some as kindling. My only concern was that as larch is quite a resinous wood, is it wise to use it in a woodburner - increased risk of chimney fire?
Glitch
23 Oct 2020
London
Yes, I'd read that and it won't be going in my woodburner.
MARK.B.
4 Jul 2012
East Yorkshire
If it is dry you should have no problems using a few sticks of larch kindling to get you're fire going:)
Jameshow
4 Oct 2020
Bradford
I've just put a big log of leylandi on the woodburner is that resinous?!
Cheers James
Glitch
23 Oct 2020
London
Cheers James
The SSW facing boards on the shed that really catch the heat from the sun are still oozing sap. I might use some scrap pieces on the outdoor fire pit if it's not too smokey.
I won't be using it on the indoor wood burner.
MARK.B.
4 Jul 2012
East Yorkshire
Leylandi burns well when dry and is very resinous but if your stove is working ok and burning at the right temperature then you should have no problem with it,have burnt several large ones over the years with no issues:)
Jameshow
4 Oct 2020
Bradford
Thanks but I'm tempted to turn the straighter sections.
Cheers James
