Siberian Larch offcuts. Keep or not?
Glitch
23 Oct 2020
London
I've got 30-40 offcuts of Siberian Larch cladding from my shed build. Roughly 320 x145mm
Having a tidy up and need to decide whether to chuck them or not.
Thought I could make bird boxes and offer them to neighbours.
Any other suggestions?
Bird/Bat boxes(y). Or Laminate them together with contrasting wood layers for turning or band saw boxes etc, mind you the temp in my shop is dropping fast so kindling for the wood burner would be my choice ;);)
I’ve also quite a stack of larch offcuts from a workshop build and had wondered about using some as kindling. My only concern was that as larch is quite a resinous wood, is it wise to use it in a woodburner - increased risk of chimney fire?
Yes, I'd read that and it won't be going in my woodburner.
If it is dry you should have no problems using a few sticks of larch kindling to get you're fire going:)
I've just put a big log of leylandi on the woodburner is that resinous?!
Cheers James
Cheers James
The SSW facing boards on the shed that really catch the heat from the sun are still oozing sap. I might use some scrap pieces on the outdoor fire pit if it's not too smokey.
I won't be using it on the indoor wood burner.
Leylandi burns well when dry and is very resinous but if your stove is working ok and burning at the right temperature then you should have no problem with it,have burnt several large ones over the years with no issues:)
Thanks but I'm tempted to turn the straighter sections.
Cheers James
