Hello Eric, welcome to the forum. Not sure we can
guarantee helpful advice mind...
£300 budget eh? Hmm, might need to get creative here... First up, have a trawl through some of the back threads on here if you haven't already. You'll see two recurring bits of advice. 1. Get a copy of "Woodturning, A foundation course" by Keith Rowley and 2. You'll get more lathe/chuck/tools for your pound/euro/buck if you can go secondhand. I don't know if you've already got safety gear, a grinder, abrasives, finishes etc? If not, you're really going to have to make that budget stretch.
One good piece of news; you can get away without buying a chuck very well. I've been turning for 4 or 5 years now, not an avid turner mind you, and still haven't felt the need to get one. Anyway, let's have a go:
Book: See above £17
Lathe:
Perform CCL £170 (just like my Delta, which is fine, but cheaper. Drat
Tools:
Perform set of 6. I know they always say "don't buy tools in sets", but this is really a pretty good one and well reviewed. A bargain at the price. £60
Safety visor:
like this or similar £7
Sharpening: This can get expensive. At the least you need a reasonable grinder, a good rest and probably a gouge grinding jig. For the latter I went with the Sorby one, but it's a ghastly £40 odd :shock: About the same price as my grinder in fact... If you don't have a grinder either, then you could be looking at near £100 on the sharpening stuff alone.
Workholding: A drill chuck is vital IMO, so I went with a good one with a drawbar and nut so I could use it as a mini chuck too.
Peter Child is the place for these. Also their face plate is excellent in all respects. But those two would set you back about £48
I have a feeling we're getting over budget... One other thing I decided was worth the investment was a
cone friction drive at £13. This is a real boon when you're starting; instead of the wood snatching the tool from your grasp if you "catch" (which you will), the work simply stops turning. Worth every penny as far as I'm concerned.
Hmm, I'll stop there 'cos not including the sharpening we've gone over the £300 mark. And that doesn't allow for abrasives, finishes, or wood!
You could knock back the lathe a bit and get the
Perform CCSL instead, but it's capacities aren't so good. Oh well, it gives you some stuff to consider anyway. I should start combing the local paper and classified ads in the woodworking mags for a set of lathe, tools, chuck etc going secondhand if I was you
Cheers, Alf
