Hi all,
I have been following this forum for many years. I am nearing the end of building a small workshop/office and I would like your advice on the door frames I am hoping to get started on in the next few weeks. It's been a long build (started at the beginning of covid lock down). Time, money, work, family, a lot of procrastination/research and questioning my abilities - I'm a plumber by trade so please go easy on me.
There will be two doors and frames, both outward opening (to maximise space in the workshop and the office door, just to match).
I have 6 x 2 redwood timber for the frame, 2 x exterior grade fire door blanks and hardwood lipping, and a bunch of mahogany type door frames I would like to use for cills. I know there are better materials that could be used but this is what I have.
I have possibly a million questions I could ask but it would take me forever to write them, so hopefully with some pictures it would make more sense, and you could let me know if you can see anything wrong with what I have in mind.
![20240328_161640.jpg 20240328_161640.jpg](https://cdn.imagearchive.com/ukworkshop/data/attachments/159/159370-9d1b6bf3da57f0c1a19b948e1a9f4e59.jpg)
With a 44mm door would a rebate width 47/48mm be about right to account for the Aquamac seal? Also, depth of the rebate - 15/20mm?
![20240328_161624.jpg 20240328_161624.jpg](https://cdn.imagearchive.com/ukworkshop/data/attachments/159/159371-2d2cac5c32fccf92d6a19bb64287aee9.jpg)
I have rough cut the heads of the frames over sized. Would a straight mortise and tenon suffice or haunched M+T. If so, would the haunch be on the external corner of the joint? Horns would then be cut flush with the verticals.
![20240328_155810.jpg 20240328_155810.jpg](https://cdn.imagearchive.com/ukworkshop/data/attachments/159/159381-f88a2a05302f5685f874b073daf383df.jpg)
The mahogany type frames would be too short to stick out beyond the cladding and reach back to the flooring, so I would need to add a piece to the back. There is a fire strip groove already in the frame I could use as the drip edge of the cill. I plan to M+T the frame to the cill. I also have some mahogany or sapele 1" x 1" I could route a chanel into the cill + weather seal for the bottom of the door.
How far beyond the cladding would be best for the cill to sit?
![20240328_152801.jpg 20240328_152801.jpg](https://cdn.imagearchive.com/ukworkshop/data/attachments/159/159386-8b09cee2c61079fb409dd2c7bf7fa027.jpg)
I will need to sand the paint off the cills.
![20240328_151040.jpg 20240328_151040.jpg](https://cdn.imagearchive.com/ukworkshop/data/attachments/159/159389-f9573319cf80b213af99329138256cb7.jpg)
This is the wife's office side of the build. 6x2 door frame boards rough cut over sized. The skirting and architrave is for in the house. The wife has also started and roped me into doing MDF panelling in the livingroom and new window boards.
Sorry for the many questions for a 1st post.
I know I'm making life hard for myself for what I'm looking to do, but I also see it as a good learning curve and to push myself out of my comfort zone.
Thanks all in advance
Craig
Craig
