Kalimna
- Joined
- 18 Nov 2009
- Messages
- 1,275
- Reaction score
- 2
Greetings folks,
Just a simple question - I've started having a go at making some boxes (a small elm and ?mahog box and a purpleheart and laburnum bigger box). These are my first attempt at boxes, so consist of 4 sides, a lid and a base rebated into a plough-planed slot (loving the Veritas plough plane, but not when cutting against the grain on purpleheart, nosirree).
The corners have been simple mitred (and after a little advice here and construction of 45 deg jig for shooting board, not *too* onerous) and I understand that inserting a spline from the outside corner is a good way of enhancing the strength of an otherwise not-very-strong joint.
So to my question - is it better/easier/normal to glue up the mitres then cut the spline slot, or cut the spline slot first, then glue all up together?
Cheers,
Adam
p.s. will post piccies for comments when finished
Cheers,
Adam
