(almost) finished five parers for myself. It's always easy to not finish stuff you're keeping for yourself (the three on the right need to be finish glazed and then bevel ground and sharpened, which is usually before handles).
The handles are gombeira - a monstrously hard and dense (denser than water) wood. The gloss finish on them is probably 3 drops of 2lb cut shellac (for the three on the right). Those three will turn uniformly dark brown like the others within a month and the color variation is just how deep the oxidation was before turning the handles (the blanks were previously roughed). Weird stuff - a crack with no light exposure will turn brown. light exposure will turn brown- everything seems to make it brown, but never to the center.
The two left handles are shellac only, but embracing modernity, I started sanding thin CA into the handles with very fine sandpaper, sanding it back and then applying finish. The objective is to get things done fast and not on and off of the lathe, but filling pores with shellac leads to pore shrink later and a cake of shellac and sawdust won't stay put unless the handles are pore filled and then finished the next day.
Three on the right are just in process and need bolsters ground down and then all of the grinding done after hardening and tempering (everything that looks like a bevel or final thickness is left until after hardening or they'll just turn into bananas when they're hardened).
Switching back to guitars soon - kind of itching to work more wood, and maybe some planes.
I built this corner cabinet out of white oak for my wife's 50th birthday. I do enjoy working with oak especially with cabinetry. I have been making cabinets for 25years but I have still a huge amount to learn. The cabinet just needs a few coats of danish oil and glass and two handles and it's complete.
Another little experimental archaeology project.
A WIP 8" tondo mirror frame......
Turned and carved from green oak about 6 months ago and it's now ready for a little more carving and eventually gilding. I've based this on a 16th. century Florentine tondo mirror and roughed out a guilloché pattern onto the bolection moulding.
I wanted it to warp a little, as the original shows the same distortion, which confirms that it was turned and carved in green wood. I think the moulding and carving has increased the surface area dramatically, which has hepled to even the drying and stop it splitting.
To set out the guilloché motif I had to retain the same number of centres for the beads, but reduce their spacing on the three concentric circles. It seems to have worked ok.
I'll carve it finished over the next two days and put some egg and dart on the outer moulding.
I'll put silver on the glass and gild it when I get back to London and see if I can flog it to pay the remainder of my course fees.
What is the orange "finish" ?
Red formica on 1" birch ply. It's a kitchen table with 2 drawers to follow.
It's totally traditional except for the top material which would have been sycamore or similar. The basic design is derived from a Welsh original which had three drawers.
Had a bit of pre-christmas idle time so put it to constructive used. This TV tray is a mixture of various offcuts and a bit of masonite. No.... not inlayed. Zig saw puzzle assembly. Interesting how the colour of the pieces change at different angles. Merry christmas to you all!!
I'll try again in the right place. Pens again, the casein one to show the colour a bit better and two in London Plane for my wife. She really envied the two I gave away so the Tempest is like them, the Zephyr is more like the pen I made that she is used to - she uses a pen alot, she's used six refills in just about as many months.
Decided to make some special Christmas Decorations for my wife. Snowmen were straightforward, turned from Laurel as it's nice and white. The tree is made from the trunk of our first ever Christmas tree, 38 years ago (nah I lied it's a spare bit of 4x2 but had you going for a second :)). The tree took much longer than expected and I ran out if time, I want to re-turn the top 2 sections as they don't look quite right plus it's finished in sanding sealer! I'll sneak it back into the workshop in the new year.
Happy Christmas everyone.
Some incredible work being displayed on this thread, allow me to provide some balance
I built a cabinet for my (nearly) new bandsaw as the metal base it came with does not seem to be be designed with efficient storage in mind. Or mobility.
It's 18mm birch ply and as its the first cabinet I have ever made, I pretty much butchered it despite my best efforts. Peter Millard made it looks so easy too :-D I used dowels and glue to connect it all together, I probably should have used a dowel jig. Its functional, and looks ok, but not quite the perfect finish I was hoping for.
The castors came from toolstation and can hold up to 170kg each - probably overkill. Well, definitely overkill but the bandsaw is heavy and I figured I should go heavy duty. Anybody ever tried lifting a bandsaw? Surprisingly heavy aren't they :-D
I also had to saw down the sides of the drawers because I designed it with ZERO tolerance between drawer and cabinet. What was I thinking? I basically designed a piston.
lots of lessons with this one
Martin
Starting to get a few things ready for a house (and workshop) move, so being paranoid about all my tools getting jiggled about during transit got me wondering about this Kaizan foam stuff. So as a treat to myself i bought a whole bunch of it. The cutting out of the foam is very therapeutic and extremely satisfying!! Done these 4 drawers so far… lots and lots more to do!!
Oh boy that appeals to my OCD. What do you cut the foam with?
