Jacob
New Luddism. Wake up and resist.
No you have missed the point - which was to compare two notable UK heatwave months in the global context. It's simpler than you think.Well it’s hot and I’m tired after a long day, so it was tempting to reply to your condescending and sarcastic dig with an equally rude reply. However, I won’t. But I will have one last go at explaining what I mean. First of all, remember that I’m not disagreeing that climate change is real. I just think that using bad examples to prove a point is counterproductive. I also think that calling people who you think disagree with you stupid (as you clearly infer I am) is a bad thing to do, so I’ll treat you with respect and try to explain what I mean in a different way.
The infographic is generated from an applet on the NASA web site. Anyone can use it. It uses a set of data from 1951 to 1980. The developers have identified places on the earth with reliable temperature records for that time period, for example London. It takes an average of the temperatures over those years for that place by month. The applet then allows anyone to enter a year and month and generates an infographic that compares that month to the AVERAGE temperature for the same month, averaged between 1951 to 1980. A colour is used to show how much hotter or colder the ACTUAL temperature was compared to the average of the same month 1951 to 1980.
So the first infographic shows that in June 1976, in the UK it was hotter than the average temperature in all the Junes between 1951 and 1980. No dung Sherlock, I think we knew that. What relevance does that have to climate change? GIGO.
The SECOND infographic is relevant. It shows that in June 2022 there were widespread anomalies, i.e. based on AVERAGE temperatures in June between 1951 and 1980 the ACTUAL temperatures recorded were significantly different over a very widespread area. It could be argued that the data set that this is based on is too small to have any statistical relevance, but not by me.
