Front door canopy - treated or untreated
vala
10 Nov 2013
Milton Keynes
I'm building a small canopy to go over my front door out of 4x2 and 3x2 and was wondering on whether it's still ok to go with untreated timber as it will be stained/protected once complete?
Any suggestions or advice is welcome.
Unless you are going to paint the canopy, wood preserver is a good idea.
If you use preserved timber after a few months you could still paint in a traditional manner,
just use Dulux silver primer, which will seal most surfaces, followed by undercoat and gloss.
Or prime as you go when building it.
https://www.google.co.uk/search?q=dulux ... B600%3B600
Its very good stuff and does what it says on the tin.
Regards Rodders
I made the garden gate of spruce (whitewood) at my last house 23yrs ago. It's still there with no rot. The parts were soaked before it was assembled, then ali primer, two undercoats and Weathershield gloss. Belt and braces - life's too short. I think I painted it twice in the interim.
As a friend once said - isn't it funny how when you can't find time to do something properly, you can always find time to do it again.
The people who want the canopy want it stained in a rich mahogany so as to match (as close as) the framework of their front door and window.
I'll be sure to do a good few coats of Cuprinol and allow the required drying time before staining it. Looking at some Ronseal stain at the moment and according to the blurb, that will protect as well, so combined with the Cuprinol before hand hopefully it is as best protected against the elements in the future.
I think you will have problems with the cuprinol being spirit based and the Ronseal is waterbased,
I would expect problems with the Ronseal taking to the cuprinol.
Rodders
Rodders - thanks for the heads up.
Is there something else that's waterbased which the Ronseal would take to that I could use beforehand instead?
