American Black Walnut Drawer Unit
MooreToolsPlease":rlqau2lr said:
Are those fillets glued in? would this be a potential problem with the movement of the parts?
Oh Jesus! forgot about movement, with the grain of the sides running the same way as the top I had got it in to my head everything was ok. Many thanks for spotting it. I'll attack it tomorrow with a jigsaw or chisel a v and cut it in two three separate pieces. :shock:
MTP (Moretoolsplease) pointed out I had a potential cross grain problem so this morning I cured the problem by chopping out the fillet and making it three fillets, this was done to the other end as well. I had to compromise where I made the gaps because the boards on the top are not the same width as the boards on the end pieces.
The face frame for the back panel has to have slots cut to house loose panels, here I am cutting a 6mm wide slot and with two passes will be 7mm deep. (sorry about the focusing)
Top rear face rail done. But not without a mishap :(
The mishap, I dropped the board on the floor and broke off a great chunk right on the corned of the mitre :( It took me more than half a hour to find the missing bit, boxxxxks anyway I did eventually find it, I just hope it blends in when the finish is applied.
Rear face end pieces fitted both with a stopped housing/dado, dunno which it should be called, going more senial every day. :)
Front face lower rail fitted. this one is fitted using just glue and two pocket screws each end.
:lol:
Thats looking nice, i'm sure once it's sanded and finished you won't even see the mistake - I have a few small ones like that on my table leg to repair after they blew whilest chopping the mortices, now they are glues it's quite hard to see them unless you are looking specifically for them.
The stiles that divide the drawers were fitted this morning so the front face is done. They are fitted using two pocket screws at each end.
Back face rails and stiles routed out with a 6mm groove and will be fixed to the unit using floating/loose tenons.
With the tenons glued to the carcase all the parts are dry fitted to check the sizes for the panels.
I had to Rip two boards down so each panel can be bookmarked. There was quite a lot of stress relieved after doing this and it was a close call if there was going to be enough thickness to get them flat, I managed it but only just.
A quick scrape
I ripped off the sapwood and here i'm using my small panel sledge to cut them to size
All four panels fitted with no glue, just a good sand and scrape off tomorrow then I can fit the draw guides, with that done the body is finished.... Just four draws to make.
:lol:
A question about the drawers, I've built this with a mind that the draw fronts will be flush with the face, but I'm mulling over the fact that I could make them a little bigger and have them protruding out the thickness of the front, or I could even leave them the same size as the opening and let them recess say about 1/4" so they look much like the back panels. What does the forum think?
Really nice LN. I wouldn't recess the drawers, it might look like they are badly fitting. If it were me, I would fit them flush.
LN wrote -
Usual practice is to set the drawer fronts back around 1 or 2mm from the front surface to create a shadow gap, but it all depends on the type of effect that you're after - Rob
Boy you work fast LN, wanna job :)
I would leave the drawers flush on this piece, I feel it would work better, but only if you can get them dead flush.
Dom
Dom
No problems with that I had intended to make them about 1" short then screw a stop behind the drawer, I could even make that adjustable and try woodblokes sugestion.
Another question what wood for the drawer sides and back?
I usually go to my offcut box. but traditionally dont they use any seasoned timber available for these parts and the least expensive
First thoughts were tulip/poplar, what is the most common used?
edit....
Just had another thought about the fronts, which way should the grain run? they are nearly square, the rails are obviously running horizontal but the uprights the grain is vertical, everything tells me it should be horizontal but I'm not so sure.... :?
edit....
LN - almost any timber can be used providing it's hard wearing and stable (not prone to movement) Generally quarter sawn oak is used about 8-10mm thick for the sides and a little thinner for the back. A better colour match for the ABW might be some hard maple if you've got any in stock. The drawer front grain should I think be horizontal, this would also give scope to make some half-lapped d/t's for the front joints - Rob
