weight of router bit
sunnybob
wysiwyg
11 Oct 2014
cyprus
Any body here know how to decide what speed a certain router bit should be used at? I'm contemplating buying a large diameter 1/2" bit but my makita router does not have speed control.
The manual just gives a vague "match weight to speed" but no specifics.
Any weight / speed charts out there?
I'd prefer actual charts rather than seat of the pants "feel" :shock: :roll:
Lons
14 Feb 2010
Northumberland
That's something I've never thought of, as Marcros said I've only ever considered the diameter of the bit.
You learn something every day.
sunnybob
wysiwyg
11 Oct 2014
cyprus
Thats annoying :shock:
The cutter I was going to buy is rated for only half the makita speed.
I dont mind pushing the envelope a little bit, but I'm not going to push it while I'm holding a sharp knife.
back to the shopping list (hammer) (hammer) (hammer)
Thanks very much.
Simon_M
14 Mar 2019
Awbridge, Hampshire
A router bit has a mark that indicates the minimum amount of shank that should always be clamped and also the maximum rated speed not to be exceeded. Both properties are specific to each router bit to ensure safe operation e.g. Trend mark their bits on each shaft, others put them in easily lost instruction sheets.
Initially I couldn't see the point of having a variable speed control but I now realise that the speed only needs to be turned up if it's required (mostly it isn't) and the safe operation speed can be adhered to - (obviously) the dice are loaded more in your favour if you consider both of these parameters.
sunnybob
wysiwyg
11 Oct 2014
cyprus
its a big makita and it spins at 22,000 rpm. a bigger bit will take more power and on an underpowered router just might work. But mine will spin any damn thing I put in it so its too big to chance.
sunnybob
wysiwyg
11 Oct 2014
cyprus
I'm now looking for a variable speed controller. In the USA they are 20 dollars or less. I cant find in the UK except for an amazon item but thats only 8 amps and i need 15.
Anyone?
MikeJhn
Grunkel
2 Sep 2014
Kent
There are mechanical ones that fit on your router, don't have a link sorry.
MikeJhn
Grunkel
2 Sep 2014
Kent
It's just a knob on a bracket with a flexible shaft that has an end on it that you fix to the dial on your router.
MikeJhn
Grunkel
2 Sep 2014
Kent
In that case it won't work on your's, you will need a VFD (variable frequency drive) they can be expensive or as cheap as chips on e-bay.
Simon_M
14 Mar 2019
Awbridge, Hampshire
My 1/4" Makita has six speeds: 1 = 10,000, 2 = 12,000, 3 = 17,000, 4 = 22,000, 5 = 27,000 and 6 = 30,000.
Router bits e.g. Trend have a marked max RPM e.g. a smaller bit might be limited to 28,000 - so setting 5 gives a bit of safety. Perhaps the quoted speed drops a bit but it's wise to play it safe? A bigger bit e.g. 31mm shaped bit will be rated at a lower speed e.g. 18,000 - so setting 3 is a good choice.
With a lower speed there is less risk of burn or the bit over heating. There are 15 or 20 amp router speed controllers e.g. on Amazon - but they are not particularly cheap and don't control the speed linearly according to the reviews.
A 1/2" diameter router bit might still be rated at 28,000 rpm - so matched to a router's output if full load speed drops a bit. Problems come when the diameter is much bigger - like a lathe the appropriate speed to maintain a linear cutting speed quickly drops.
MikeJhn
Grunkel
2 Sep 2014
Kent
Single phase too single phase VFD's are about £50.00 that will have infinite control over router speed, some more expensive versions have constant speed control so no matter what the load the speed will be constant.
GrahamF
11 May 2015
Abergele and Portugal
Anyone?
Is this just for the router?
How many HP is it? 2HP is 1500 watts = only 6.25 amps
sunnybob
wysiwyg
11 Oct 2014
cyprus
I'm not prepared to spend 50 quid plus on a speed controller for just one cutter, which in itself is another 50 quid.
ta, but I've changed my mind.
