vacuum press fittings
neilricketts
21 Mar 2007
Hiya i am in the process of building my own vacuum press but i need a supplier of the fittings that go through the home made bags. Can anyone suggest a good supplier in the uk.
Cheers Neil
Airpress sell them (£40)
http://www.airpress.uk.com/frame_set.ht ... mables.htm
They are purpose machined out of aluminium with a self sealing connector - the underside of the base of the fitting is machined to prevent sealing against the 'other side' of the bag. A hidden expense it that you will need to buy the other half of the connector. The bag fitting has a male connector on - you will need the female half which is normally the more expensive bit as it contains the latching mechanism etc.
However, you could make one as all they are is a male connector with a nut either side of the bag and a rubber washer for a seal (add a decent diameter washer so it does not topple over in use), but by the time you have got all the bits, messed around etc the ready made solutuion is probably not too bad value!
BRgds
S
BRgds
S
I live within striking distance of Airpress and the last time I went past it, the building was up for sale, so I'm not sure if the company has gone to the wall? - Rob
Hi, thanks for replys finally been able to check the forum after 2 days of no internet. All i need now is to win the vacuum pump on ebay.
cheers neil
