I'm hoping to tap into the Wadkin sawbench wisdom here.
I've got an old Wadkin PP table saw that I'm partially rebuilding. It will take dado sets. I've got the arbor off for new bearings.
I'm tempted to turn the 1¼" (31.75mm) shaft down to 30mm … I've got some 30mm tooling that will fit, but it also seems like a good idea for long term sawblade availability. The retaining nut and thread won't be affected because the threaded end of the shaft is already 1 1/8" (a bit less than 30mm) in diameter.
But … if I do it, the saw flanges will have to be bushed as well as the existing blade, from 1¼" to 30mm. That's a small bush.
Does it make sense? What are the downsides to machining it to 30mm? Would it be better to leave it in its original size?
