Megaweasel
Hi everyone - AGS 10 restoration is going very well - actually much better than I expected with my ham-fisted engineering and painting skills. I didn't do a full restoration blog as there are several of those - much better than I'd be able to do, but here’s the traditional before/after photos:
Quite a way to go yet - need to sort out the top and the fence. The good news, despite the alarming burn mark on the front is that the machine was in great condition. no cracks or breaks and the two machined quadrants look like new. I believe it spent its life in an RAF training facility. Other than purchase cost and transportation, I've spent on the motor (see other thread) for which I got a great deal on eBay on a new TEC motor, and I also got a local engineering company to sort out the arbor so it runs correctly, and also got it refitted into the spindle housing as that was far too stiff for me to get the bearings in. Whereas before it was out by about .2 of a mm, its now less than 0.05 (tested with a dial gauge). New bearings and new bushes, new belts (also see other thread) mean it should give me years of service. Here's where I got to so far before the top goes on:
I need to fix the knobs for the handles as the top rims are broken, and it was missing its name plate which I've managed to get from eBay for 6 quid! Needs painting though. Haven't decide to use the old switch gear or stump up for a new one - they don't look as nice but I'll assess the safety of the old one first.
I'm viewing this as a 'resto-mod' type of thing - I want it to be as good - if not better than a modern cabinet saw. For anyone considering this, I've spent £350 on the saw, £200 on transport (went and got it with a van), £90 on the motor and postage, £125 on engineering and approx £50 on bearings, belts, bushes etc - so around £800 so far although you could probably remove the £200 transport if you got it delivered. I think once the Fence is done, I should be at around £900 - possibly just over as the mitre gauge is a bit rubbish and I think it deserves better.
so to my question - I need a nice new quality blade or two. I like the Axcaliber blades and there is a good offer on a combined set at the moment: Axcaliber Premium Saw Blade Package but its 30mm bore. They also have a 30mm to 5/8 adaptor - will this work? is it going to be a compromise? If it is, where can I get a similar premium blade or two with a 5/8th bore. I've used these and CMT blades with the anti-ringing laser cutouts and have found them to be great (the old bent blade fitted in the picture makes a right old racket when I tested the motor/measured the speed).
bonus question (Deema?? Sideways??) : bits left over - what is this? I took it off and I painted it - no idea what it is or where it came from
. Really should have taken more pictures...
Cheers!
Chris
![ags10-original-1.png ags10-original-1.png](https://cdn.imagearchive.com/ukworkshop/data/attach/139/139496-ags10-original-1.png)
![ags10-original-2.png ags10-original-2.png](https://cdn.imagearchive.com/ukworkshop/data/attach/139/139497-ags10-original-2.png)
![IMG_2410.jpeg IMG_2410.jpeg](https://cdn.imagearchive.com/ukworkshop/data/attach/139/139499-IMG-2410.jpeg)
![IMG_2412.jpg IMG_2412.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/139/139500-IMG-2412.jpg)
Cheers!
Chris
