gidon
How accurately do you get the blades set (parallel to the outfeed table)? I spent an hour last night readjusting the planer blades. The Scheppach 260 comes with a little jig that must get pulled exactly 3mm on rotating the drum, on each blade on either side of the blade. The trouble is this is made of metal and the blade doesn't always grip it too well. So I used a planed piece of wood to do the same job. But incredibly fiddly to get spot on. So how spot on do you get it? I found that mine was way out before I set it. And I then guess you have to be sure that the thicknessing bed is exactly parallel to the outfeed table? Not sure if that's adjustable.
But when the blades weren't correctly set I was getting a visible taper from right to left (across the wood).
Intested to hear your thoughts?
Gidon
Gidon
