Running shaker doors
Doctor
24 Nov 2008
Herts / Essex border
Hi,
Just thought I'd show you a few images of the way we run shaker doors
2 spindle moulders, one to run tenons
two 25mm scribing rebate blocks
By having 2 blocks rather than the one and flipping the work, the set up time is much quicker and also the tenon can be off center
one spindle to run grooves
adjustable shim block, I have a much more expensive dial up model but find this one easier to use!!!
Run the tenons
Run the groove
Job done
With this set up I can run tenons up to 35mm
hand made kitchens hertfordshire
Great idea if you have 2 spindles unfortunately I only have one :mrgreen: :mrgreen:
Can I just ask a question regarding painted shaker doors. After you have constructed them with the panel in and then painted them, have you ever had a problem with the door shrinking or expanding and then the paint cracks where the panel goes into the slot to leave a line of un-painted panel.
Thanks for that post Doc - found it most interesting
I need to run up some special size oak doors to match our forthcoming kitchen and it's quite a while since I've done any in anger.
I've only got 1 s/m as well (if I discount the Kity K5 :D ) but then don't have many to do. My tooling is a bit limited also and it isn't worth the expense I think for such a small production run - ah well - make do as usual!
Would be very interested in any other stuff as well if you can find time to post.
cheers
Bob
