Alexam
Bandsaw Boxmaker
With a table top of 7/8" thick having formic top surfaceand plywood below, could the opening for the router plate just be cut with a router straight through the table with a template of timber just stuck down with double sided tape. Or is this a 'dodgy' way to go about it?
I have seen videos where a template is cut out of another surface first then that template being used to cut/route through the table top, but when no supporting 'lip' is not needed, it seems a quicker way to work. The plate (Kreg) would be supported by the Kreg leveling blocks at each corner. ???
