gatesmr2
Hi
Sort or woodwork related
I am tyring to fit a new door where our front door used to be, now have a porch with a hardwood door so putting a normal door in its place.
My problem seems to be what i would assume is a weather strip at the bottom of the frame.
Its a strip of metal sunk into the frame but who ever installed it have made a mess of it, nothing new as i am finding loads of annoying little problems like this over the house :evil:
To start with its not straight, also its not set at the right depth as the frame, upon taking off the old door have noticed a strip has been added at the bottom about 28mm to fit the weather strip, the old door being 40mm thick.
My new door is 30mm width so i can't fit the door in, its also a hollow door so i can't shave some off the bottom.
Ok hope that all made sense so now the question ?
I want to remove the metal strip without damaging the frame how deep are they normally set and is there an easy way of removing them. I have thought about an angle grinder but as it sits close to the frame i have a bit each side of about 30mm that would mean cutting into the frame.
Sorry if i have not described it very well but any help would be very useful
Martin
Martin
