Following excellent advice received in my previous thread, I'm now facing a more challenging (for me) door situation and assessing potential solutions.
I'm seeking guidance on which of my proposed solutions align with accepted practices for such door frames.
Key observations (zoom in on the photo):
The entire door frame is leaning to the right:
- Left frame side is 15mm from true vertical
- Right frame side is 11mm from true vertical
Top of the frame is rising from left to right:
- Left side is 3mm below true horizontal
The frame is flush with the surrounding wall, but the wall (and frame) leans backward:
- Top of the door frame is 6mm behind the bottom
Internal width of the frame:
- Top: 689mm
- Bottom: 690mm
Frame thickness: 30mm
Replacement door size (standard bathroom door size): 1981 x 686
I'd like to avoid plasterboard work due to my limitations and costs. Time is not a concern for woodworking/painting tasks.
Options I am considering for correcting the frame:
Option 1 (adjust all 3 frame sides to a square box):
a. Shave left frame side (bottom to -15mm at the top)
b. Add timber strip to the right frame side (strip paint, +11mm at the top)
c. Add timber strip to lower right frame side by 3mm (strip paint from top, level it)
Option 2 (shave all frame sides to make them square and vertical):
- Do not think it is viable due to excessive width after shaving both sides (716mm vs. door's 686mm)
Option 3 (grow all sides inside to make them square and vertical):
- Reduces overall door width (664mm), narrowing the entry
Option 4 (do not modify the frame, scribe the door to the frame)
- I do not think this is viable because existing (Parallelogram) frame is already wider than the door.
Seeking guidance on the best course of action.
- Top: 689mm
- Bottom: 690mm
![Door5-Annotated.jpg Door5-Annotated.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/145/145962-Door5-Annotated.jpg)
