jasonB":2b83giw6 said:
For our chosen example of an eight sided tower with 5 degree slope it gives the mitre angle of 2.07 quite close to the 2 that we have said but the bevel angle is 22.4, probably OK for the 5deg slope to use 22.5 unless you have a wixey to set your saw by 0.1deg increments
but try altering the slope and see how the bevel angle needs to change. This may be why people are suggesting seting the saw to 22.5 which really only works for a parallel sided shape.JAson
You are correct on all counts Jason. In the earlier calculations I simply rounded to the nearest half degree. The bevel (saw tilt) should really be, as you say, 22.41º and the mitre 2.07º. And again, as you rightly point out who can set a saw that accurately?
Certainly as the slope of the sides gets more acute to the base line, eg, let's say a 61º slope, but still with eight sides, then the saw bevel setting is 19.55º and the mitre setting is 11.35º. By the time we get to these sorts of angles that simple 22.5º bevel setting for an eight sided column is disappearing fast over the horizon.
Similarly the numbers change if you add or remove a side. If we revert back to sides sloping in 5º from vertical, but with only 7 sides, then the dihedral angle is 128.78º leading to a saw tilt bevel setting of 25.61º for a mitred join, and the mitre gauge setting is 2.4º.
The 25.61º bevel setting I've just mentioned is not far from the 25.71º setting that would be used on a seven sided column where, as it is a column, all the sides are vertical from the base line. This, as I've realised you know but I'm working through here for anyone that may not have caught on, is found simply by dividing the number of sides into the 360º in a circle and dividing the result by 2, viz, (360º/7)/2 = 25.71º.
I think I've done enough calculating for one day, and probably far too much for this thread, ha, ha. Slainte.
