Masking tape
tim
5 Nov 2004
Herefordshire
I'm looking for good stuff not the paper rubbish which always seems to tear or the glue degrades within weeks of buying it so that the second roll doesn't work.
I need something that will adhere to a plastic sheet so that it will cover fabrics/ carpet but not stick so hard to painted surfaces that it will strip them on removal.
Basically, I've got myself (homer) involved in replacing a staircase ie the spindles, banisters, newels etc for a client and I need to strip and stain/ refinish the existing timber around it. The treads are open riser and carpeted so the danger to carpets/ walls etc is large!
All advice/ help gratefully received.
Tim
PowerTool
24 Jul 2005
Darlington
Go to a proper painter/decorator supplier - my local one is Glenwoods,and they have an amazing range (low tack,high tack,green stuff,white stuff..) and will give better advice.
tim
5 Nov 2004
Herefordshire
Thanks PT. Thats what I'm looking for (although ideally online on account of living in the middle of nowhere). Can anyone suggest a good online supplier?
Tim
frank
10 Sep 2003
cheshire
tim dont leave the tape on to long ie days weeks it will dry out and then it sticks good style .
frank
Scott
18 Oct 2004
And if you've had it a while and think it needs rejuvenating, chuck it in the microwave for a few seconds. Honest! .... Just a few though :shock:
devonwoody
11 Apr 2004
Paignton Devon
But don't let the wife catch you though!
tim
5 Nov 2004
Herefordshire
If I may guide folks back on track :roll:
- I'm looking for a good online supplier of decorative supplies. The masking tape will not be on for longer than 5 days but it does need to be good, robust stuff that won't tear or let stuff seep through or creep under.
Tim
RogerS
20 Feb 2004
In the eternally wet North
Tim
Travis Perkins stock a blue coloured low tack variety and it is first rate. Also has good sharp edges so you get a good paint line.
Roger
