Hi All,
I would really appreciate your help and assistance. I am having real problems with cutting mortices with my Sedgwick 571 Morticer. When I make a mortice cut, the chisel seems to 'stick' in the slot making it extremely difficult to retract. (Sometimes pulling the wood out of the vice) Once the first slot is cut, the rest are OK. However, as I cut each end of the mortice first to ensure that the slots remain parallel, its a real pain. I use Clico English style chisels. I sharpen them properly before use using the clico sharpening set. I have checked that the Morticer runs true by placing a clock on the chisel as its brought down in both planes.
I initially thought that this was just the way it is with cutting Morticer, however, recently using the same chisel, and arrangement, I did not experience the problem. I decided to remove the chisel and put it back in again, this time the problem returned. I am now convinced that this must something I'm doing when setting it up.
