RossJarvis
I'm currently fitting a "dodgy" hardwood door for a friend, this is the second old door I've done lately which is warped. The latch edge is about an inch out at the top when the bottom's home. She bought it being told it wasn't hung before, but as one stile is about 1/2" narrower than the other I think a bit of truth may be missing! The warp/bow/bend/whatever seems to be in the latch edge stile from the glazed area up. Admittedly, if I'd looked it over better I might have spotted it and put the hinges (x3) on that side which may have straightened it, but I put the hinges on the thicker stile thinking it better to put the weight hinge side.
Any ideas if there's any way to flatten it? It's panelled at the bottom and glazed at the top. It's internal so not a major draught issue. If there's enough flex in the door, generally with a bit of a push the latch can often hold the thing flat, but I've not shot (shooted/shuted/planed/butchered) it in yet as it's a bit wide and it seems fairly rigid and I don't think it'll flex enough.
PS, why would the hinges she bought (Zoo ball bearing) have 4-5mm stand-off, you could park a bus in the gap! I've recessed the hinges to close it up but don't like the look of this.
