since i had mentioned the mafell, and did not know , i went today and checked some things about the festo and rail.
was lucky enough to meet the london area manager, and posed some questions, so in my aim to become a smart buttocks on festo here are a couple of things i learnt.
i mentioned the complaint about getting joined rails straight and in line.
he suggested the following. first clean the joining edges to make sure there are no bits of rubbish there, for instance if the rail has been lying in sawdust, it might affect the join.
next if you are using a sheet of mdf etc, then place the straight edge upside down on one of the straight (manufactured )edges then pull the other one along it, and use the connectors, and tighten them whilst it is upside down. this should ensure it follows the line of the board you are attempting to cut. then turn the guide onto the board, and tighten the top joiner screws. next when you mount the saw remember to use the green buttons to ensure it is tight and aligned within the rail.
that may well be more difficult than on the ez system, but may answer some of the questions that have been previously posted.
second i asked about the angle cutting adapter, and was told that there is a central screw which should be tightened to provide the correct angle.
finally i asked about whether they had anythinglike the ez repeater.
no but. what they do have is a system for allowing you to use the rails and offset a router from the edge accurately to make holes for shelf supports.
the bits of this are available seperately, and may be a little narrow, but i think could be adapted to allow up to 6 inch depth.
look at part numbers 583160, and the parts of that set 485758, since they fit the guide rail, would work with the saw too.
anyway enough polishing their reputation,if they need it, but it might be useful to some of you.
paul :wink:
