EasyScribe - has anyone used one?
paulm":3safuole said:
Compass with a pencil in it ? :)
Cheers, Paul
Yes I have tried that. However I cannot find one that locks securely!
And if you look at the video you will see that the EasyScribe seems to make door fitting easier which I don't think you could do with a compass and pencil?
Hi Charlie
Normally i would just scribe free hand using finger like so.
If scribing a door in i use these glazing packers.
I always carry a pair of dividers in my box and sometimes will use these .You dont need to to spend any money on gadgets there is always a cheaper way .Also dont have to search in the tool box to find my finger and the pencil is usually behind the ear.
Cheers Bern.
I sometimes use a washer, just put pencil in the hole and roll it round the object to be scribed.
It's quite neat though. But it has 2 major drawbacks IMHO. Price :shock: , and second; special pencil leads. These are going to let you down at some point by being unavailable, maybe just because you forgot to stick one in your box. They should have just stuck on a pencil (available everywhere) as per old fashioned compasses, but then it'd look just like a pair of old fashioned compasses and nobody would buy it.
I give it 1 out of 10.
Many thanks for all the replies and suggestions guys. I think I will try and find a good quality compass that won't change setting as I use it.
These things are always too expensive for what they are. You wouldn't mind if it was £10-£15 but £25 is just too much. Just like all the other scribing devices. I will stick with me pencil and a packer.
I use one of these http://www.axminster.co.uk/faithfull-fa ... rod911052/
Locks in position and takes a standard pencil. Not sure I paid that sort of money for it though, might be able to find something cheaper with a bit of googling ?
Cheers, Paul
Cheers, Paul
Paul
Thanks for that. Are you happy with the quality of yours?
Only place that I found it cheaper than Axi was Amazon http://www.amazon.co.uk/Faithfull-200mm ... uctDetails
Sorry Charlie, should have said that I use something like that Faithful version, with the same kind of locking arrangement, not that particular one.
It's just a compass, nothing much to go wrong I wouldn't think.
Cheers, Paul
The tool looks well thought out, and well made.
It is rather expensive for the advantage it offers over simpler approaches.
BugBear
We used one of these (see link below) when i was an apprentice. The long point makes it much more useful and accurate. I bet you could pick one up for a few pence at a car boot sale. They are pretty redundant things now though as most scribes are cut via a mitre from a chop saw.. maybe useful for a few occasions though, such as scribing skirting to uneven floors etc.
http://www.ebay.co.uk/itm/Vintage-Brass ... 3cd79a37b7
I do loads of scribing, generally I use one of these which looks like a cheap compass at first glance but because the back is flat you can hold it flat on the wall with two fingers. I have found this to be the most accurate FOR ME.
http://www.zimmereibedarf.com/product_i ... 19047ef87b
Yours looks like a nice tool and probably better than the one I linked to, I think the led thing that Jacob referred to is true and I think it probably looks a bit desirable to leave around on site.
Yep that's what I used to use. Looks better but it isn't, sometimes stuff that looks better quality and better made isn't as good as the cheap plastic alternative.
Oryx , do you buy them from there or is there a UK seller. Looks like it's 25 Euro for shipping :(
