RogerS
I always find it fascinating to see how others make things. You can spend ages poring over a piece of furniture and think that you've seen it all but then when you get back and start looking at some high-res photographs you see things that you missed. The glue line in what you thought was a single moulding, for example.
And then sometimes you ask yourself...'Why?'...as in this case.
From the external side, this glass framed door seems to have a scribed joint (shown by the arrow)
but look at the joint from the inside and suddenly it's not so clear cut. If the joint was a normal scribed joint...and I see no reason why it shouldn't be...then you'd expect the scribe line on the rail to end up where I've shown a dotted line. Instead it finishes where it does (shown by arrow) which seems to me an awful lot of extra and unnecessary work to do it like that. The interior beading is screwed in place after the glass is fitted.
Hence my question....why?
