Silverbirch
Thinking of the sketch I posted earlier, I`ve finally come up with something akin to what I had in mind for the idea of "balance".
I turned the base and ball from oak, then scorched, wirebrushed and sprayed it black.
The bowl section is sycamore.
The three components are separate and balanced in a state of equilibrium.
The bowl has a curved base so it returns to an upright position when rocked, rather like a budgie toy.
The ball naturally centres itself in the depression on top of the bowl shape.
My thoughts:
1. I think the ball is too large ( and not very well made - need to practise that )
2. The pedestal is too wide in relation to the size of the bowl. Or, it might work better if it was shorter and more curved at the waist.
3. I think the bowl needs to have more of a curve from rim to base, so that it is a segment of a circle.
With hindsight, I should have drawn the pieces to scale and worked from measurements on my drawing, as you can`t make overall adjustments as you go along when you`re not working on a single piece.
I`ll try to rework some/all of the components and post a "mark 2" version later.
Your thoughts and comments welcome!
Ian
My thoughts:
Ian
