mickthetree
Hi all
I'm pretty sure I have located the cause of my very slight blade wobble on my startrite table saw. The rear arbor bearing was worn.
I have stripped it all out and bought replacement bearings, however in putting it back together I see that, where there has been some wear with the old bearing, the arbour has been reduced in diameter. To the point where it is a sloppy fit on the new bearing. I don't have a micrometer, but my digital calipers measure it at 3 thou. The inside ring of the bearing does not rotate when the arbor is spun and if I give the whole thing a tug I'm sure I can feel some very minute slop in it.
Is there anything I can do / try before buying a new £120 arbor?
Would some sort of bearing lock fluid take up that much slack? Anything I do must keep the shaft central in the bearing or I will end up with a blade out of true again.
Many thanks
Many thanks
