What sandpaper rolls?
scholar
14 Jan 2009
Stratford-upon-Avon
Most of my sanding is done with my (Festool) sanders for which the range of abrasive pads is fine for me.
For hand sanding, I just pick up a roll of whatever I need and is available at Screwfix etc. The last lot I got is very poor and doesn’t last at all (not sure it is branded, coloured brown). This suggests I ought to get a bit more organised.
The only time I have taken much notice of what rolls to buy was on a recommendation to get some Hermes J-Flex sandpaper which is cloth-backed and very good - I recall it was expensive, so I save it for “fine” work!
The job in hand is a sizeable refurbishing of painted windows - what good quality stuff can others recommend?
Does abranet fall into the "fine work only" category? I think it is brilliant and while expensive, lasts so much longer than cheap rubbish...
Another vote for Abranet - much cheaper on the roll than pre-cut.
Jim
Thank you - it seems like I need to get with the times and get some Abranet, which I have not used before.
I believe it can be used on Festool (and other) sanders with an intermediate Velcro layer - presumably all versions, precur or on a roll have the same backing that will fix to the intermediate Velcro?
@Sideways I will look at the Mirka hand sanding block - I have a Festool one that is very good for rubbing down paintwork between coats - hopefully with said Velcro intermediate layer, I can use the one I have.
If you're using the stuff on a r.o. sander try 3M Cubitron discs. They're better even than Abranet.
These are good with discs (although they've gone up since I bougfht them several weeks ago) -
https://www.amazon.co.uk/dp/B08XB2ZBBS?ref=ppx_yo2ov_dt_b_product_details&th=1
Yes thanks - I was thinking of that and did look into Cubitron for my sanders a while ago (but I still have a large stock of Festool pads to get through) - it does look very good.
The original query here was what to use for hand sanding where I have been using whatever crappy stuff was to hand.
I’m not aware that Cubitron comes in rolls(?)
No, I don't think it does, that's why I got the round sanding blocks.
Most of my stuff on reels is Mirka, most of my discs are Klingspor - I tend to use this when sanding dirty or sticky work as when something's going to clog quickly I don't see much point of wasting expensive abrasives.
Yes, the abranet on a roll and precut all fits directly onto a Valcro Pad such as the Festool ones. Extraction performance is excellent.
Jim
