condeesteso
An odd question? But I think it's worth consideration. We're all familiar with the basis of measurement (inches, mm, Bob's Rule etc) so it seems obvious, although I have seen arguments saying stop using a rule as quickly as possible when making anything. There is a thread here about some chisels that seem to maybe come out not exactly the width stated - and this is NOT specifically about that but it did prompt it.
I think a measurement is the exact replication of another dimension. If we need a measurement to travel a long distance we need a common code (a ruler) but in the workshop, the first stretcher is the best ruler to set the next 3, and that basis applies for every repeated dimension. After all, a mortice gauge isn't what we regard as a ruler is it?
In fact, I think rulers are one enemy of design because if you work to dimensions off a ruler, it stops the eye looking at what is right. I like the idea a table top may end up 1476mm long because that looks right when the legs are 773mm high - and neither were ever 'rulered'.
If you are replacing or replicating something, the best reference is the original or the hole it left, a rule only introduces error.
The fact that an American may replicate an old European piece in inches, or European replicate an old American piece in mm serves to remind that a rule is like a currency - it is no accurate gauge of anything, just a reference of length or value.
There is plenty of evidence supporting the fact that a measurement is just a value we can all understand (like currency) and it's a simple language form enabling us to communicate with each other. But it's not a good way to make things. Witness the story stick, for example.
Let debate commence.
