Hello all.
Don't wish to hijack the thread regarding Wealden tools.
But thanks for the concern and helpful advice.
It is a spindle moulder I meant. I normally do curved work on my router table with a disposable blade bearing cutter (from Wealden which is highly recommended,
http://www.wealdentool.com/acatalog/Onl ... m_269.html)
I dont have a pin for this either but i usually leave a straight section on the template to lead first.
The sections I have been doing recently are just too big for the router cutter, hence the interest in the bearing ring.
I have used ring fences with bonnet guards before.but with these the ring is larger than the cutter block so you only have a very small contact point (if that makes sense).With the bearing being the same size as the block making snatching possible, is that correct?
So the advice is make a lead in pin of some sort.and have fence as close as possible. Could I make a ring fence out of ply?
Davin
