Wouldchuk
Here's an easy one - what homemade shelf system are you using to store you turning tools?
I want a tool rack for around 20 chisels (seeing as that's what I inherited, give or take) to mount directly above the lathe. I was thinking about a simple shelf, with two rows of 50mm holes cut with a hole-saw. Through each hole insert a piece of plastic tubing around 200mm to 300mm long, glued and screwed into the shelf, and with the cut-outs from the holes glued and screwed at the bottoms to close the tubes. The tools would then drop into the tubes handle down, leaving the ferrule (which have little stickers on to remind me what is what) visible. I should say, I onlyhave around 800mm of width, hence thinking a shelf around that by 150mm deep with a double row.
Any better ideas?? Any inspirational pictures of your setup much appreciated.
I inherited the lathe a couple of years ago (CL4 variable, with a bunch of tools) and after all this time with it sat at my parent's, and having only had a few sporadic sessions, I have finally installed the lathe closer to home so am looking forward to some more frequent turning - tonight for the first time in over a year I got back on it and started turning a piece of 6inch diameter hawthorne into an end-grain bowl. I think my tools are somewhat blunt, but it felt good to have the shavings flying! Not sure when I will get on to the hard bit... the hollowing!
I may try and get to the Didcot woodturning club if there are any others on here who are members?
Cheers,
Tim
Cheers,
Tim
