TrimTheKing":x4cgn0p6 said:
Eric The Viking":x4cgn0p6 said:
Thing #2: cable modem behaving 'normally'
Not sure what 'normally is, but okay.
It's a Motorola dartboard -- old but it's been fine (screwed to a beam above the bench I'm fettling planes on at the moment, up in the attic!). I"m getting a normal light sequence: TX + RX connections OK, data flowing and occasional activity.
Thing #3: some servers (such as my mailserver, which is physically nearby) are reachable, when things like the BBC site aren't.
When you say 'physically nearby' how do you mean?
The work one is down the road, physically in central Bristol. Domestic email is from Yahoo (US).
Sometimes, during fault conditions, my local (in the house) mailserver's log shows it could reach Bristol, but not Yahoo. Sometimes both have failed together, in periods of total loss of connectivity, including port 80 stuff too.
Thing #4: it comes and goes, and slows down and speeds up (using web pages as a guide).
Could be a link issue, could also be a contention issue. Have (can) you check the stats on the modem to see if you have a high CRC error rate on your WAN interface?
It's broadband cable rather than ADSL, so I wouldn't expect high CRC errors, as there's far more margin/bandwidth available in the 'local end' (it's fibre from the green box in the pavement, literally outside the house next door). I haven't got a local RT entry for the modem's web server at the moment, so I'd have to plug a laptop directly into it to look at its logs.
Thing #5: when it does work, long-distance (e.g. NZ) is significantly slower than normal, but reachable, implying an odd route.
Hmmm, routing can be an odd beast but your only routing concern will be getting from your house into Virgins network, after that it's their internal routing then out onto their country peer, so that would affect many more people than just you.
I think it's at best an area fault, at worst smoke in somewhere like Telehouse! I didn't explain myself very well earlier (crucial evidence about Virgin admitting the problem was omitted!)
You mention tracert, it would be worth getting a tracert of a known problematic site now, while it's working, then get the same again when it goes castors up. This will tell you where any routing issues might be coming in.
Yep. Here's the obvious one:
Code:
Tracing route to ukworkshop.co.uk [92.48.118.217]
over a maximum of 30 hops:
1 * * * Request timed out.
2 11 ms 19 ms 11 ms 10.45.136.1
3 9 ms 8 ms 9 ms osr01azte-v15.network.virginmedia.net [80.192.0.1]
4 12 ms 11 ms 11 ms aztw-core-1a-ge-200-0.network.virginmedia.net [80.1.242.1]
5 21 ms 19 ms 16 ms winn-bb-1a-as0-0.network.virginmedia.net [213.105.175.157]
6 19 ms 17 ms 70 ms brnt-bb-1b-as5-0.network.virginmedia.net [213.105.172.234]
7 25 ms 28 ms 33 ms brnt-bb-1a-ae0-0.network.virginmedia.net [213.105.174.225]
8 15 ms 15 ms 22 ms nth-bb-b-as4-0.network.virginmedia.net [212.43.162.218]
9 18 ms 18 ms 20 ms tele-ic-1-as0-0.network.virginmedia.net [62.253.184.2]
10 219 ms 207 ms 192 ms 114-14-250-212.static.virginmedia.com [212.250.14.114]
11 43 ms 29 ms 27 ms 213.133.130.78
12 24 ms 23 ms 26 ms bac.bsq3-hex.as29550.net [217.112.81.94]
13 22 ms 24 ms 22 ms mayall.calynet.co.uk [92.48.118.217]
Trace complete.
Ignore the first line - I have a deliberately misconfigured DNS server, which is causing the apparent odd timeout. It's a long story, but it's not an actual problem.
The most likely if the routing tables are regularly reconverging is a flapping route/link somewhere causing a routing relationship to flap, probably in 'the cloud' somewhere.
Makes sense to me. Of course, I forgot to mention the important thing: called them on Friday and today and in both cases (when pressed) they admitted they had a problem. First-off it was all the 'restart your modem' nonsense.
Regarding the speed of rebuilding routing tables, I wasn't explaining quite what I meant: It's behaving as if they're repeatedly restarting some bit of kit/cluster/whatever. Anyway, it's been up for four hours so far - longest since the trouble started.
I'll be saving this week's email logs too...
