studders":3v2uk7kk said:
TrimTheKing":3v2uk7kk said:
You need to get some traceroutes of sites that fail
A what? (and how?)
My web space provider is in US and I get some very long delays when using their admin panel. Would the above help or is it not related?
I don't want to sound patronising so, how much do you know about IP connectivity?
I will assume not a lot for the purposes of this.
Firstly a basic intro to IP routing.
In very basic terms, all computers that want to talk to anything across the internet use a protocol called TCP/IP and each one will have a unique address (known as an IP address). Now there are public IP addresses (which are routable across the internet) and private IP addresses (generally used on your internal home network, and most likely to be an address in the following range 192.168.*.*) which are not routable across the internet.
Everything (and I mean everything) that wants to send info across the internet has to have a public IP address ( or proxy through one at least), and that includes all home pc's and all websites.
Okay, a tracert (or trace route) is a way to test what routing path your traffic is taking to get from your pc to wherever you are trying to contact.
To do a trace route you need to do the following (I use WinXP so it may be slightly different on Vista or 7, and on Mac's)
-Start
-Run
-In the box you type cmd and press enter. This will bring up a black DOS window
-Now pick a website and type the following - tracert
www.yourwebsitehere.com (see example below)
C:\Documents and Settings\Mark>tracert
www.google.co.uk
Tracing route to www-tmmdi.l.google.com [216.239.59.147]
over a maximum of 30 hops:
1 111 ms 99 ms 99 ms bebox.config [192.168.1.254]
2 * * * Request timed out.
3 * * * Request timed out.
4 * * * Request timed out.
5 * * * Request timed out.
6 22 ms 23 ms 22 ms 87-194-0-206.bethere.co.uk [
87.194.0.206]
7 42 ms
23 ms 23 ms
64.233.175.27
8 44 ms 33 ms 38 ms
209.85.240.158
9 39 ms 37 ms 35 ms
66.249.95.169
10 47 ms 39 ms 50 ms
216.239.49.114
11 39 ms 36 ms 38 ms gv-in-f147.1e100.net [
216.239.59.147]
Your output will look something like the above but don't worry too much if it's not the same numbers (in red), different ISP's will give back different responses depending on their routing path. What you need to worry about is if you do this one day when the site is working fine and get one set of results, then do it again when it's going slowly and see what you get. If you get a different set of red numbers that before then your traffic is taking a different route.
This doesn't automatically mean that there's a problem as traffic can legitimately take a different route depending on if there are devices down on the internet, but may well point towards there being a problem.
However, if any of the numbers with ms next to them (have highlighted one in
cyan) are particularly high (high hundreds) then this
could (but again sadly not guarantee) suggest that there is a device which is slowing things down somewhere along your routing path.
Hope that wasn't too boring
PS I'm not entirely sure why lines 2-5 are timeouts but there may well be firewalls/routers in the path that are set to not respond to ICMP packets so i'm not altogether worried by this.
