AC induction motors, also known as asynchronous motors, use a rotating magnetic field to produce torque. Three-phase motors are widely used because they are reliable and economical. The rotating magnetic field is easily achieved in three-phase asynchronous motors because the phase angle offset between the individual phases is 120 degrees. However, single-phase AC motors require external circuitry which creates the phase angle offset in order to produce a rotating magnetic field. This circuitry can be realized using advanced power electronics, or more simply using a motor capacitor.
