RogerS
I finally got around to getting one of the vertical digital gauges. Not that I want to thickness down to fractions of a millimiter...just that I kept getting caught out and finding that i had to run an extra bit of stock through...which meant that I needed to check all the others etc.
This way, I can go back to a known setting spot-on.
Mounting was a doddle...just the existing holes on the thicknesser carriage, a small spacer and a plate cut from a duff CD. A couple of tapped holes in the main frame held the body of the vertical gauge.
Roger
Roger
