squaring up my rage evo 5s
Roboboyo
25 Apr 2022
London
hi guys, well i've been trying to square up my rage 5s table saw using a box digital level, but once i square the blade to 90 i then lock it in place, but because the locking lever requires a bit of pressure it seems to knock it off square and the box level reads 89.7 after locking
anyone else experience this?? is there a tip to lock it at 90?
The locking screw may have a bit of a burr on its tip which is causing deflection as it tightens. If so grind/file it to nice smooth dome.
Brian
Set the angle with a less precise instrument, such as a combi square.
Yes, just find a square that's 0.3° out in the right right direction and your saw'll be fine.
The point you have missed Phil, is that you wouldn't know either way with a combi square, hence the problem would have disappeared.
