Jacob
New Luddism. Awake and resist!
If you are doing it freehand it's useful to have a visual guide like CC's above. Mine's a wooden wedge cut at 30º. Have it alongside your stone as you hone. You soon get used to guessing it close enough.Webby":24513qy9 said:ok .....I have read all the posts so 25 to 30 degrees looks like the way to go .............but you have now ground the angle and honed it to razor sharp using said angles
how do you know you have ground/polished these angles spot on ...do you check them with a protractor or is it really trial and error
i.e. its not cutting well so i need to redo .......
before any one jumps in I am not de crying anything just curious to how you know
ok Dave :wink:
Or you just do it by eye - 30º is a 1 to 2 incline (1 vertical, 2 up the slope) or half an equilateral triangle, so it's not hard to visualise.
The main thing is to avoid raising it with every honing.
The second main thing is to get a burr right across the middle. The middle gets most wear and so tends to be the last bit to get re-sharpened and is easily neglected.
