MikeG.
There are 4 parts to this question, as there are two similar shaped but different spec'd doors. Here is the door:
The outer door (shown in the above drawing) is ledged and boarded, and the door follows the shape of the arched head. I need a suitable level access threshold arrangement for such a door (I'll use a weatherbar to help with that detail). The edge seals along the straight bits are easy, but how do I cut a 2.5mm slot into a curved spandrel, and how do I deal with the short grain issues? I can't even think of a scratch-stock that would work for the job in oak.
The inner door is much chunkier (nearly 75mm thick), so I don't have the same problem at the bottom edge (where I also need a level access threshold seal), but I do have similar issues to the outer door at the arched head. Both inner and outer doors open in.
Any help greatly appreciated.
