I found a manual online for an earlier version of the 300E and noticed that the rip fence mounting now has one part less than it used to have! I've found adjusting or removing the fence to be a real PITA so decided to make something similar to the "missing" part
So much easier to use now. It's the grey block in the picture with the two handwheels.
The table insert supplied is too thin for the table and does'nt support the work as well as it could, also the slot is rather wide so I made a new one from a plastic off cut, all I had in 5mm thick material was clear Polycarbonate but it works good.
