Just found a photo of one of our "Chartwell" benches in situ... at Chartwell!
Note that the National Trust don't generally like oiling the benches we made for them - they get many 1000s of visitors a year, some of whom are definitely gravitationally challenged! Some gardens put them under cover in the winter, some don't, so the life of these very expensive hand-made benches is often harder and shorter than it could be...
The complex design and construction of the back of these benches has been problematic for us, and some have needed remedial work after time in the field. Lessons learned and all that.
Collected and stickered some local larch. Mainly to do the facias and soffits on the new outhouse roof, but also aiming to dry some to use to make the door.
it was a b***h to turn with conventional lathe tools. bits of wood would tear out, lay across the edge, and the balsa was so soft, it wouldn;t cut it.
Ended up using a template and a router to rough n shape then using varieties of auto-body rasps and Ariou style rasps to tune it to size. Steady rest will possible, was not applicable, as any vibration would just cause the bearings to severly indent the wood (It did marginally for the maple ones I turned)
Video at
Balsa sands ever so easily so it was easy to smooth.
I found an on-off foot switch (for lathe)greatly aided effeciency.You lift your foot, holding router in one hand, and reaching for calipers with the other.
Eric in the colonies!
Got given a scruffy old cupboard, bottom doors missing, glass missing, heavily painted,
Made a pair of doors which fitted OK but thought I'd better strip it first
Stripping turned into mega job - paint came off easily with hot air but varnish underneath was like thick toffee so hunted down some serious stripper, Nitromors type
Turned out to be very nice pitch pine and worth the effort. Didn't have any for the doors so will paint them. Put new (old) glass in the top doors - reclaimed horticultural from an old conservatory - has a nice ripple like old cylinder glass. Puttied on the inside - much quicker than knocking up beading, and putty is nice and solid, no rattling etc
Linseed oil all over.
It was a school cupboard and full of pin holes and drawing pin points etc so will have to pick out paint bits and fill with wax.
I was really pleased with it as it was touch and go for firewood at the start.
A buggler fitting hinges into hinge pockets which had been worked over lots of times and used up the last of my Baldwin cast iron - which are world's best ever hinges.
View attachment 121323View attachment 121324
View attachment 121325View attachment 121326
View attachment 121327View attachment 121328View attachment 121329
Turned out to be very nice pitch pine and worth the effort. Didn't have any for the doors so will paint them. Put new glass in the top doors. Linseed oil all over.
A pipper fitting hinges into hinge pockets which had been worked over lots of times and used up the last of my Baldwin cast iron - which are world's best ever hinges.
Hi Jacob, nice cabinet, that’s beautiful pitch pine, Baldwin cast iron hinges, is that the same Baldwin from the US that did brass foundry, really and I mean really nice bress castings, candle sticks, locks, hinges, etc?
I also need some 3 and 4”cast iron hinges for a job soon what are the chances of getting any pls? Ian
Toddler swing from leftover timber. Had a go at splicing too. Frame sized for room to grow
Sure the kid will love it.
Now to cast my sailor's eye on those splices. Not bad at all for a first go and you got the thimble eyes reasonably tight too. They most definitely will never pull out but you only need 4 tucks per splice. Next time you can save a bit of work.
John
You can get them on Ebay but expensive.
The main thing is to watch out for scrap joinery/furniture. The hinges last forever and are well worth saving. Just drop them in a bucket of caustic and when dry and cleaned off - apply linseed oil.
https://grandvictorian.co.uk/the-baldwin-hinge/
There's a few small birch burrs sitting on the bench in the workshop, a couple of spare hours took care of one of them at least.
Another wee kuksa / whisky noggin for sipping your favourite beverage, ideally around a campfire 🔥😊
