My front door ws replaced two years ago with a fairly expensive (IMHO) accoya door.
It has vertical slats in the bottom half, which have plainly been held in with pins. I say obviously not because I can see the pins, but I can clearly see rust marks bleeding through the paint where pins would be. It was filled and painted (Sadolin Superdec, so not cheap paint either
) but after 18 months the first rust runs started to appear.
I compained ot the door maker who stated they only use stainless pins, so can't understand how it's happened - but has since gone quiet when it comes to resolvng te issue...
So - to my problem - how does one treat rust on metal pins that can't be seen? Does normal rust converter adversely affect wood and/or paint?
Is there somethng I should paint over it with?
All advice gratefully accepted.
