matthewwh
Mattty":mxf7r79o said:On the subject of the Ash. Iles, my only other gripe with them was the stickers on them. They are a pita!
You're not alone, so we fixed it last november.
I'll pop a bit of orange oil in your parcel, if you peel off the sticker it will shift any remaining residue in a jiffy without harming the underlying surface.
I use the mirror technique too but find 3/4 of an inch or so adequate to begin with, the shiny bit will tend to creep back up the blade over time.
If you use narrower strips of film near to the edge and work across them, or work across the width of a waterstone you can polish around the inside of the concavity and get a bigger shiny bit in less time. Using the technique in the video you are reducing the concavity slightly without the risk of eliminating it completely. A bit of both may be the best bet?
