hammer n nails
have ordered my new blades from mike what do you use for lubrication i am told that you must do this how often and with what
thanks in advance.................Roger
Chippygeoff":22fte7d3 said:Covering the pattern helps prevent burn, lubricates the blade.
NEVER lubricate blades.
Scrollerman":31smd7bv said:Chippygeoff":31smd7bv said:Covering the pattern helps prevent burn, lubricates the blade.
Hmm Chippygeoff,
Which one is true ?
stevebuk":27kqfo4t said:Scrollerman":27kqfo4t said:Chippygeoff":27kqfo4t said:Covering the pattern helps prevent burn, lubricates the blade.
Hmm Chippygeoff,
Which one is true ?
You need to read it again scrollerman, what Geoff is saying is that the clear tape you cover the pattern with helps to lubricate the blade, do not lubricate the blade itself.
HTH
Mike M":2p86bi9j said:The tape has a silicone on top, so you can un-roll the tape.
Silicone releases friction, it is not a lubricant.
You can even take a can of silicone and before you put it on the wood, spray a very little mist on the pattern, put glue on the back and glue it on the wood. The Silicone was dry before I knew it and no residue got on the wood.
FD Mike
Chippygeoff":ews8j0od said:Hi Roger.
Maybe I should have been more specific in my reply. It does not take a university degree to understand what I was trying to get across as some of those who replied to your question Roger did not seem to grasp the meaning. Its not rocket science to understand such a simple thing. Packing tape serves several purposes when cutting hardwood as I have explained. What I should have said when I said NEVER lubricate the blades was that never put oil or grease on the blades, not only will it stain the wood but it is doubtful if the blade would stay in the clamp when the saw is turned on.
stevebuk":3qzqeqj9 said:so are you saying scrollerman that unless you get an answer from 'Highly respected' people who scroll saw you will take no heed, if so you know who to direct your questions to in future.
stevebuk":3qzqeqj9 said:You need to read it again scrollerman, what Geoff is saying is that the clear tape you cover the pattern with helps to lubricate the blade, do not lubricate the blade itself.
HTH
stevebuk":2msh0lgh said:i wont be adding anymore to this thread..
