Peterthegardener
I am restoring an old river boat. The previous owner fitted a standard 2" thick domestic door to the main cabin, but there is not enough room to open a 24" door because of a floor step so the door is divided into 2 parts which means I get 20" usable opening when both leaves are open. I am hoping to replace both parts with a single leaf 21" wide and 1" thick and so gain valuable layout space on board. I have some oak which is chunky enough to plane/thickness to 1" x 3.5" from this I plan to make a door from 2 stiles and a top, bottom and middle rail all morticed together and pegged. I intend to fit panels of 1/2" exterior plywood into the top and bottom spaces.
This sounds to me as though it will be sturdy enough, but perhaps more the experienced will tell me otherwise?
What I am unsure about is how to lock the door. It will open outwards. Although I could perhaps cut another mortice and fit a standard lock it would leave me very little material on either side of the lock case. Do I fit cover plates over this to strengthen the door? Alternatively I could fit some sort of rim lock, but most of these are designed for inwards opening and many of them seem to specify thicker doors as well. There are some specialist locks designed to fit to a single sheet of plywood for marine use, but these all seem to cost over £100 and I'm not sure that they would work with my 'thicker' door?
What I am aiming for is moderate security for no more than about £50...... is that possible with this set up?
