My father in-law has given me this old line painter. Unfortunately it was damaged in a garage fire a few years ago.
I vaguely remember using it to mark out a badminton court many years ago and it's clear how the wheels and the wheel "scraper" go together. I'm a bit less clear on how the handles were. The "MCC Wonder" plate must go between the handles about half way up where there are nuts and bolts. What I can't work out is how the handle would have been.
Father in-law thinks it had two wooden handles facing towards the user. If that was right then I guess the handles must have had a hole down their length for the bolt to fit through. Once I've straightened the handle arms out a bit, it will be clearer.
I'd be really grateful for tips on how to deal with the iron work. I think I'll have to cut the bolts off or drill them out to get it all apart and replace with new. Is it then just a case of wire brush to get the rust off before painting, or should I soak in something?
For the handle arms, should I heat them to straighten them? I only have a blowtorch - will that get it hot enough?
Nick
Nick
