BearTricks
Hi,
I’m making cupboard handles for my kitchen. The ones we currently have are unusual sizes so the ones we want to replace them with don’t fit. I also just like the challenge of making my own for (almost) free rather than paying a few hundred quid when I have the materials lying around at home.
I’ve got some 12mm steel and aluminium pipe. I’ve managed to make a prototype out of the steel. The design is very basic, similar to this:
I don’t do much metal working so my initial idea was to punch where I want the arms to be, drill a 12mm hole on the drill press, press the arms in, then braze/solder. My thoughts were that the friction of the hole would provide more grip and more surface area for the solder. My prototype seems plenty strong enough for the amount of use it will get.
My process is hit and miss and is liable to grip the tube and chew it to bits no matter the speed or amount of coolant. I’ve tried working my way up through drill sizes but it doesn’t fix the problem. The tube is clamped but the drill wants to wander so getting the arms at the same angle is also a problem.
I’ve seen people make a jig for a hole saw, like a poor man’s tube notcher, but I can’t find a 12mm hole saw from a reputable brand. They all seem to be cheap Far Eastern Amazon jobs which I don’t trust. The smallest the likes of Starrett do are 14mm.
I suspect the answer is to compromise and size up to 14mm, notch the ends of the arms in a jig, and probably weld instead of solder, or do what I’m doing now but notch an offset hole through the pipe sideways (which I think will have the same profile as just drilling straight in to it) so I might be answering my own question here. Does anyone have any better tips on how to do this, or know where I can source a good quality 12mm hole saw?
![IMG_0439.jpeg IMG_0439.jpeg](https://cdn.imagearchive.com/ukworkshop/data/attach/161/161611-IMG-0439.jpeg)
