Quantcast
Incra iBox - Anyone familiar with it?
oobaa
22 Feb 2019
London
Hi
Just got hold of an incra iBox but struggling a bit to dial it in
I’m getting a slight (<1mm) mismatch on joint boards as in the pictures
Played around with the microadjuster to loosen / tighten joints but when the joint is a nice fit I get the mismatch
Any ideas / advice welcomed - thanks
oobaa
22 Feb 2019
London
Hi - yes watched them 2 or 3 times
Not sure it’s the height of the cutter as the height/length of the fingers seems ok
Something is causing the boards to misalign slightly.... grrrrr
sunnybob":2yx61pxs said:
adjust the router cutter height.
Belay that! Just looked at the ibox demo and my advice is not relevant for that gadget :oops:
Have you checked incra's videos?
https://www.incra.com/precision_fences-ibox.html
boardgamer
13 Jul 2017
Suffolk
What result do you get if you lower the cutter height by 1mm or so?
oobaa
22 Feb 2019
London
Hi - if i reduce the cutter height, the fingers protrude less but the board long edges are still out of alignment
boardgamer
13 Jul 2017
Suffolk
Ah yes, apologies, I missed the point!
Is your "kiss" calibration spot on? I assume (never having used the iBox) that 1/2mm inaccuracy here could translate to 1mm in the joint.
oobaa
22 Feb 2019
London
think so... can't get a piece of paper between the cutter and guides - but worth more experimenting I reckon
Stanleymonkey
15 Jun 2014
South West London
Probably not helpful - but are you reversing the boards somehow? The fingers seems a good tight fit and ready to be trimmed down. It just seems like one board ha been reversed or started at the wrong edge?
oobaa
22 Feb 2019
London
Pretty certain the boards were orientated correctly - I def marked them up ok
I’m beginning to wonder if it’s related to the tightness of the joint fit and/or the kind as alignment
Back to trial and error on cheap Wood :)
Sleepy
5 Mar 2017
Durham
How do you do your first cut on the second board? You need to flip over the first board, put its first cut over the fingers and the butt your second board upto it. Your first cut on the second board should cut to the edge of the board. It looks like something is going wrong there.
peter-harrison
25 Jan 2018
Cambridge
It looks like a problem with the positioning of the stop that you slide the boards up to. This will set the side-to-side positioning of the workpiece. it can't be the height of the cutter, as it's in the wrong plane.
oobaa
22 Feb 2019
London
I flip the first board so it’s marker faces the fingers and it’s first cut is over the fingers
Butt the new board to that its marker is also facing the fingers
Remove first board
Make cut
I think you are right though - if I am getting that wrong somehow - even if only <1mm, it would explain the misalignment
Given the same type of error occurs every time - I’d assumed a setup problem - could easily be user incompetence though :)
