PaulO
I got a new (to me) hollow chisel morticer last week, a Sedgwick 571. It came with a mixed box of mortice chisels, some Wadkins, Ridgeway, and a bunch of Chinese ones. All of them were pretty abused, with blunt chisels and augers showing signs of blueing.
So I decided to buy a few new Draper Expert ones based on the recommendations here. The problem I am having with them is that the tip of the auger appears to be slightly larger than the chisel. So as I cut the mortice, slight scallops are left in the walls. This would be fine for blind mortices as they would be covered by the shoulders of the tenon. But I am concerned about the finish of through mortices.
So, should I
a) Reduce the diameter of the tip of the auger? I plan on doing this by applying a diamond stone to the outside of the auger while it is running (so not taking any metal of the chisel, but reducing the auger to match the chisel)
b) Cut my mortices undersize and take a cleaning paring cut with a hand chisel?
c) Buy a different brand of mortice chisel?
d) Stop being so fussy?
e) Something else?
Thanks for your help
So, should I
e) Something else?
