BigShot
Hey folks, I'm just about out of ideas here.
A while back I bought a workshop full of tools from the widow of a cabinetmaker who had died. In with them was a shop-made router table with router. Today I'm trying to use it for the first time, but unfortunately there's a bit in the collet and the nut won't budge.
The first I knew of the problem was when I put a pin through the hole in the shaft, turned the nut with a spanner and felt the plastic bits (that hold the pinned shaft in place) snap off. "Oh, great."
Since then I've gone through an assortment of old tools (a screwdriver, two allen keys) which I've broken or bent while trying to hold the shaft in place to turn the nut. Even gripping the shaft with (padded) mole grips and turning with the spanner hasn't given any joy... nor has heating the collet nut a wee bit to try and get it to expand a bit and loosen off the shaft so I could turn it.
The router is a Bosch POF 52 if that makes any difference.
I dread to think how long the bit's been in there. Probably a couple of years. Of course, it's not the bit I need either - otherwise I'd just get on with the job and come back to the problem later. Ah well.
Any advice on this would be much appreciated.
