mac1012
by jove I think the penny has just dropped decided to take the pulley of and was scratching my head how the the hell it works , I was an engineer machinist ahem 30 years ago and the oily bit in my brain suddenly came alive !
I tought that shaft must come out of the pulley so I put the nut on and gave it a ht with a persuader put the nut on to hit that so as not to damage the threads ( see I told you the oily bit in me came alive )
and out it came ! revealing the correct shaft with shoulder !
then the penny dropped .... the pulley should spin on this shaft ! well it certainly wasn't it was wedged in tight so the whole shaft was turning with the pulley thus turning the nut which should be stationary so everything was just turning and binding on the legs , no wonder it wouldnt go very well !!
this bush in the pic below was inbetween the legs so I assume that is correct as this allows the nut to tighten against the frame and the other end of bush presses against the other leg and the shoulder on other side ? if you don't have the bush the nut has nothing to tighten against and will squash the leg
this is pulley with very rusty hole and has a tiny hole where you should put a few drops of oil to keep the shaft lubed up (behave)
power tool this is the v shaped cup on the top
now where is my 3 in 1 oil ??
